OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1735 Discussions
Why my CPU Intel does not show as available?
Alexandre_D_3
Hello to all,  first time I am posting something here, I installed the SDK OpenCL intel.
A simple question, I have a GPU AMD and Intel (R) Core (TM) i5-5200U CPU, I wanted to know why, when I run the code "CapsBasic" only appears as an option the AMD GPU device. It was to show the CPU intel device also , or I need to install any drivers?
 I installed the Intel SDK for OpenCL Applications ™ 2016 R2.  Using linux. I think the CPU driver version is: 1729.3 (SSE2, AVX)
I thank you all for your understanding
Jeffrey_M_Intel1
Since you have multiple GPUs, the first thing to test is if the Intel GPU is visible to your system.  You can do this with lspci.  There is a wrapper for this check in the system analyzer: https://software.intel.com/en-us/articles/mss-sys-analyzer-linux
You will need to install a driver package in addition to the SDK package.  There are two ways to get one:
From a Media Server Studio Generic install:
(Or you could use the Gold OS, CentOS 7.2, which has a more automated install which only requires updating the i915 module instead of recompiling the entire kernel.)
From the standalone OpenCL 2.0 driver package
Tamer_Assad
Innovator
Hi Alexandre,
First, make sure you are referencing Intel CL (headers and libs), not AMD's
then, you might want to try calling "clGetDeviceIDs()" and pass "CL_DEVICE_TYPE_CPU" to the "cl_device_type" paramter.
Tamer
