OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
clEnqueueCopyBufferRect crashes with access violation in cpu_device32.dll
ABoxe
I have several calls to clEnqueueCopyBufferRect to copy data between two device buffers.
After a few calls, I get a crash with an access violation.
I am using the 2014 beta sdk, targetting my Intel i7 cpu.
Here is a code snippet:
size_t bufferOffset[] = { 0, 0};
		   // The region size must be given in bytes
			size_t region[] = { img_size.s[0] * sizeof(type_data), img_size.s[1] * sizeof(type_data) };
			clEnqueueCopyBufferRect ( oclObjects.queue, 	//copy command will be queued
				          (cl_mem)d_odata,
						  (cl_mem)(d_idata),
						  bufferOffset,	//offset associated with src_buffer
						  region,		//(width, height, depth) in bytes of the 2D or 3D rectangle being copied
						  tile_comp->width * sizeof(type_data),   //length of each row in bytes
						  0, //length of each 2D slice in bytes
						  tile_comp->width * sizeof(type_data) ,   //length of each row in bytes
						  0,
						  NULL,
						  NULL);
			err = clEnqueueBarrier(oclObjects.queue);
			SAMPLE_CHECK_ERRORS(err);
Aaron
Raghupathi_M_Intel
Sounds like you maybe writing beyond the buffer boundaries. Did you narrow it down to some issue in the runtime? Anyway you cannot create and attach a small reproducer?
Raghu
ABoxe
Thanks. Yes, I fixed this -  the error was here:
The y coordinate should not be multiplied by sizeof(type_data).
So, nothing to do with bugs in the library.
