clEnqueueNDRangeKernel may fail on kernel with 2D local arrays but succeed with 1D local arrays and manual index computing.
For example, the following matrix multiplication kernel fails with CL_OUT_OF_RESOURCES if USE_2D is defined and succeedes otherwise.
Matricies are [24, 72] * [24, 72]T = [24, 24] and BLOCK_SIZE = 24.
#define BLOCK_SIZE 24
#define C_WIDTH 24
#define AB_COMMON 72
__kernel __attribute__((reqd_work_group_size(BLOCK_SIZE, BLOCK_SIZE, 1)))
void mx_mul(__global const float *A,
__global const float *B,
__global float *C) {
#ifdef USE_2D
__local float AS[BLOCK_SIZE][BLOCK_SIZE];
__local float BS[BLOCK_SIZE][BLOCK_SIZE];
#else
__local float AS[BLOCK_SIZE * BLOCK_SIZE];
__local float BS[BLOCK_SIZE * BLOCK_SIZE];
#endif
int bx = get_group_id(0);
int by = get_group_id(1);
int tx = get_local_id(0);
int ty = get_local_id(1);
int a_offs = (by * BLOCK_SIZE + ty) * AB_COMMON + tx;
int b_offs = (bx * BLOCK_SIZE + ty) * AB_COMMON + tx;
float sum = 0;
for (int i = 0; i < AB_COMMON / BLOCK_SIZE; i++, a_offs += BLOCK_SIZE, b_offs += BLOCK_SIZE) {
#ifdef USE_2D
AS[ty][tx] = A[a_offs];
BS[ty][tx] = B[b_offs];
#else
AS[ty * BLOCK_SIZE + tx] = A[a_offs];
BS[ty * BLOCK_SIZE + tx] = B[b_offs];
#endif
barrier(CLK_LOCAL_MEM_FENCE);
#pragma unroll
for (int k = 0; k < BLOCK_SIZE; k++) {
#ifdef USE_2D
sum += AS[ty] * BS[tx];
#else
sum += AS[ty * BLOCK_SIZE + k] * BS[tx * BLOCK_SIZE + k];
#endif
C[get_global_id(1) * C_WIDTH + get_global_id(0)] = sum;
Tested on Ubuntu 14.10 and Core i7-3770 with intel_sdk_for_ocl_applications_xe_2013_r3_sdk_3.2.1.16712_x64.
This issue seems to be resolved in intel_sdk_for_ocl_applications_2014_beta_sdk_4.0.1.17537_x64.
Topic Options
