OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
clReleaseMemObject just after clEnqueueTask causes segfault
kazum
OpenCL spec says that clReleaseMemObject() doesn't delete the specified memory object if there are queued tasks which use the object.
https://www.khronos.org/registry/OpenCL/sdk/1.0/docs/man/xhtml/clReleaseMemObject.html
> After the memobj reference count becomes zero and commands queued for execution on a command-queue(s) that use memobj have finished, the memory object is deleted.
However, the following example code causes segmentation fault on my environment (emulation with Intel FPGA SDK for OpenCL 18.1).
  • kernel code
__kernel void sample(__global char * restrict s) { s[0] = 'H'; s[1] = 'e'; s[2] = 'l'; s[3] = 'l'; s[4] = 'o'; s[5] = '\0'; }
  • host code
#include <stdio.h> #include <stdlib.h> #include <string.h>   #include <CL/cl.h>   #define KERNEL_FILE "sample.aocx" #define KERNEL_NAME "sample"   #define ARRAY_SIZE (1024 * 1024)   static void check_status(cl_int err, const char *api) { if (err == CL_SUCCESS) return; abort(); }   int main() { FILE *fp = fopen(KERNEL_FILE, "r"); if (fp == NULL) { fprintf(stderr, "Could not open file %s.\n", KERNEL_FILE); exit(1); } fseek(fp, 0, SEEK_END); long file_size = ftell(fp); unsigned char *binary = malloc(file_size); if (binary == NULL) { fprintf(stderr, "Could not allocate memory.\n"); exit(1); } fseek(fp, 0, SEEK_SET); if (fread(binary, file_size, 1, fp) != 1) { fprintf(stderr, "Could not read file %s.\n", KERNEL_FILE); exit(1); } fclose(fp);   cl_int status; cl_platform_id platform_id; cl_uint num_platforms; status = clGetPlatformIDs(1, &platform_id, &num_platforms); check_status(status, "clGetPlatformIDs");   cl_device_id device_id; cl_uint num_devices; status = clGetDeviceIDs(platform_id, CL_DEVICE_TYPE_ACCELERATOR, 1, &device_id, &num_devices); check_status(status, "clGetDeviceIDs");   cl_context context = clCreateContext(NULL, 1, &device_id, NULL, NULL, &status); check_status(status, "clCreateContext");   cl_command_queue command_queue = clCreateCommandQueue(context, device_id, 0, &status); check_status(status, "clCreateCommandQueue");   cl_int binary_status; size_t binary_size = file_size; cl_program program = clCreateProgramWithBinary(context, 1, &device_id, &binary_size, (const unsigned char **)&binary, &binary_status, &status); check_status(status, "clCreateProgramWithBinary");   cl_kernel kernel = clCreateKernel(program, KERNEL_NAME, &status); check_status(status, "clCreateKernel");   cl_mem mem_a = clCreateBuffer(context, CL_MEM_READ_WRITE, ARRAY_SIZE, NULL, &status); check_status(status, "clCreateBuffer");   status = clSetKernelArg(kernel, 0, sizeof(cl_mem), &mem_a); check_status(status, "clSetKernelArg");   status = clEnqueueTask(command_queue, kernel, 0, NULL, NULL); check_status(status, "clEnqueueTask");   status = clReleaseMemObject(mem_a); check_status(status, "clReleaseMemObject");   status = clFlush(command_queue); check_status(status, "clFlush"); status = clFinish(command_queue); check_status(status, "clFinish");   status = clReleaseKernel(kernel); check_status(status, "clReleaseKernel"); status = clReleaseProgram(program); check_status(status, "clReleaseProgram"); status = clReleaseCommandQueue(command_queue); check_status(status, "clReleaseCommandQueue"); status = clReleaseContext(context); check_status(status, "clReleaseContext"); free(binary);   return 0; }
I tried valgrind, and it looks like clReleaseMemObject() deletes the memory object even if there is a running kernel which uses the memory.
==55813== Invalid write of size 1 ==55813== at 0xBC304CA: sample (sample.cl:3) ==55813== Address 0xb8a5000 is 912 bytes inside a block of size 1,049,600 free'd ==55813== at 0x4C2EDEB: free (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C42D19: acl_mem_aligned_free (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C47307: clReleaseMemObjectIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CFFE: clReleaseMemObject (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x4011BE: main (main.c:96) ==55813== Block was alloc'd at ==55813== at 0x4C2DB8F: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C41A87: acl_mem_aligned_malloc (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C49A12: clCreateBufferIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CF17: clCreateBuffer (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x40113E: main (main.c:83) ==55813== ==55813== Invalid write of size 1 ==55813== at 0xBC304D2: sample (sample.cl:4) ==55813== Address 0xb8a5001 is 913 bytes inside a block of size 1,049,600 free'd ==55813== at 0x4C2EDEB: free (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C42D19: acl_mem_aligned_free (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C47307: clReleaseMemObjectIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CFFE: clReleaseMemObject (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x4011BE: main (main.c:96) ==55813== Block was alloc'd at ==55813== at 0x4C2DB8F: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C41A87: acl_mem_aligned_malloc (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C49A12: clCreateBufferIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CF17: clCreateBuffer (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x40113E: main (main.c:83) ==55813== ==55813== Invalid write of size 1 ==55813== at 0xBC304DB: sample (sample.cl:5) ==55813== Address 0xb8a5002 is 914 bytes inside a block of size 1,049,600 free'd ==55813== at 0x4C2EDEB: free (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C42D19: acl_mem_aligned_free (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C47307: clReleaseMemObjectIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CFFE: clReleaseMemObject (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x4011BE: main (main.c:96) ==55813== Block was alloc'd at ==55813== at 0x4C2DB8F: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==55813== by 0x5C41A87: acl_mem_aligned_malloc (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x5C49A12: clCreateBufferIntelFPGA (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libalteracl.so) ==55813== by 0x4E3CF17: clCreateBuffer (in /opt/intelFPGA/18.1/hld/host/linux64/lib/libOpenCL.so.1) ==55813== by 0x40113E: main (main.c:83)
Is this a bug, or am I missing something?
HRZ
Valued Contributor III
Try compiling your kernel again another OpenCL SDK; e.g. AMD's or NVIDIA's SDK and see if your code would segfault in the same place. If it doesn't, then this is a bug in the Intel FPGA SDK. Though, I am very surprised to see that the specification claims the buffer will be freed after commands depending on it finish; the command queue information is NOT passed to the clReleaseMemObject function as an argument, so I fail to see how this function will be able to determine when the buffer is safe to delete.
kazum
Thanks for your reply. I tried NVIDIA's SDK and Xilinx SDAccel, and those frameworks worked correctly. It looks like a bug in the Intel FPGA SDK.
