OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Is Open CL compatible with Xeon E5345 or E5620
hazardsmusc_edu
Hi Folks,
I am very new (as I got an email this morning mentioning OpenCL) to OpenCL. I have a small research cluster with has
Dual quadcore Xeon E5345 or E5620 processors.
Can OpenCL work with these older Xeons?
Starr
Yuri_K_Intel
Hi, Intel OpenCL CPU runtime requires SSE4.2 instriction set. I see that Xeon E5620 http://ark.intel.com/products/47925 supports it, so yes, you should be able to develop and run OpenCL applications on these systems. I'm not sure about Xeon E5345 - you may try to run (assuming Linux) 'cat /proc/cpuinfo | grep sse4_2' command to check the presence of the corresponding flag. Thanks, Yuri
