OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
PDF Version of OpenCL 2012 Optimization Guide
Jim_Vaughn
Is there a PDF file for the OpenCL Optimization Guide? I can only find the find to the web based version here:
http://software.intel.com/sites/landingpage/opencl/optimization-guide/index.htm
_heinz
Hi Jim,
Sorry to say this: there is no PDF file of the "OpenCL 2012Optimization Guide" available at time.
Maybe it's comming some later. Don`t worry.
Use meanwhile the web based version.
_heinz
Maxim_S_Intel
Although there is no pdf ver on the web, you might want to use "offline" html versions of Optimization/User/etc Guides that are shipped with SDK itself:
Specifically, Intel SDK for OpenCL* Applications package contains the following documents:
  • Installation Guide
  • Release Notes
  • User's Guide
  • OpenCL* Optimization Guide
By default Intel SDK for OpenCL* Applications documents are in:
C:\Program Files\Intel\OpenCL SDK\2012\doc (on 64-bit operating systems, instead of Program Files, the directory name is Program Files (x86))
Still we strongly recommend to use web-based versions since those are most updated. For example the online versions already include some mistakes fixed, also important clarifications, etc. Propagating these important changes to the full-blown SDK package will take some time anyway.
Jim_Vaughn
Thanks for the reply. I realise that the online versions are the mostup to datehowever in closed environments neither the web based nor a soft copy is a viable option. Even out of date versions would be very very helpful if at all possible.
Jim_Vaughn
Is there any chance their will be a PDF anytime soon? in closed environments we really need something we can print out as the offline html files are not printable. This would be of tremendous help.
ARNON_P_Intel
Thanks for rasing this issue onve again.
We will take your ask into consideration.
Arnon
