You didn't understand correctly what @Loptop ask. He bought two Intel Processors: i5-10400 (with integrated graphics) and 10400F (without integrated GPU). Since after installation he realized that 10400F doesn't supports the old graphics adapter, he ask if he can return the 10400F and get the 10400 after paying the difference in price?
@Loptop this is not a place to ask this question. You should ask the dealer he sold the processors.
Leon
The i5-10400F does not have graphics.
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=199271,199278
[Windows 11 is the new Vista]
If I understand correctly, you've replaced an i5-10400f, which doesn't include a graphics engine, with an i5-10400, which does. Due to compatibility issues with external graphics cards, you want to use the i5-10400's graphics engine and your motherboard's support for this graphics engine. Is that correct?
This is certainly possible and easily supported. In fact, since the processors are so close to each other, you should be able to make the processor change without needing to reinstall Windows. The first time that you boot into Windows with this processor, you should see a graphics driver installed automatically. I recommend that you manually update this driver yourself. The driver package that you want is available here: https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html?wapkw=i5-10400.
Hope this helps,
Leon
i5-10400H
https://ark.intel.com/content/www/us/en/ark/products/201895/intel-core-i510400h-processor-8m-cache-up-to-4-60-ghz.html https://ark.intel.com/content/www/ru/ru/ark/products/201895/intel-core-i510400h-processor-8m-cache-up-to-4-60-ghz.html?elq_cid=6163221_ts1632878785657&erpm_id=2113522_ts1632878785657
