17065 Discussions
13900k causing program crashes
wmiller
ive been fighting issues with various games crashing, apps restarting and other general annoyances for weeks now, after deciding to re run a stress test on my 13900k i got 2 errors on physical core #4 - logical core 8 & 9. im assuming this would mean my cpu is done for and its time to buy a new one. any other insight would be great, i only ran the stess test partially but can run a full one if its really needed, posting the results here.
00:00:00 - Info - Test schedule started at 2024-01-04 03:26:36
00:00:00 - Info - CPU - Started (Duration : 01:00:00)
00:08:58 - Error - CPU - 1 error(s) found on physical core #4 - logical core #9
00:11:42 - Error - CPU - 1 error(s) found on physical core #4 - logical core #8
00:12:39 - Info - CPU - Test stopped
00:12:39 - Info - Schedule stopped by user request
wmiller
My full specs are as follows
CPU - Intel i9 13900k (No OC)
RAM - 64gb Corsair Dominator Platinum DDR5 5600 (i only used 1 stick when testing to make sure it wasn't a ram issue, ram is clock at 4200 MHz)
GPU - EVGA RTX 3080ti FTW3
COOLER - Lian Li GALAHD 360mm AiO
DeividA_Intel
Hello wmiller,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i9-13900K Processor.
1. Run and attach the Intel® Processor Diagnostic Tool:
2. Do you see any LED code turn on when the issue appears?
3. What is the name of the tool you used to run the test?
Deivid A.
wmiller
i did attempt to use the diagnostic tool, it said the hardware was incompatible. the only led that came on was the red cpu led on the motherboard, the program i used was OCCT
Alberto_R_Intel
wmiller, Thank you very much for sharing those details.
Please provide a picture of the error message that shows the hardware was incompatible with Intel® PDT.
Albert R.
IsaacQ_Intel
Hello wmiller,
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Hello wmiller,
Best regards.
Isaac Q.
