I found a bend pin of the 2011-v3 socket on my X99.
I consulted the relevant document and found that the bend pin is corresponding to the BK58 (QPI0_CLKRX_DP).
The Description of QPI{0/1}_CLKRX_DN/DP is as following:
Reference Clock Differential Input. These pins provide the PLL reference clock differential input. 100 MHz typical.
The bend pin is very close to the BM58 (QPI0_CLKRX_DN), probably a short circuit.
My questions:
Is there no QPI signals input or output for a i7 5960X CPU?
If i am right, does it mean the bend pin has no damage to my system?
I suggest you contacting the motherboard manufacturer for possible warranty replacement.
