17279 Discussions
About the relation between the number of Multi-Format Codec Engines and their performance
ZionChen
Hello!
As we know that all the new Intel processors  have their Multi-Format Codec Engines, which could fasten the speed of preview in Adobe Premiere Pro. I wonder that whether there is any difference if there is only one group of Multi-Format Codec Engines in one particular processor. For example, i7-13650HX has only one group of Multi-Format Codec Engines. Is it weaker in Pr than processors which have two groups of Multi-Format Codec Engines, like i7-13700HX? And how it will make a difference? The same problem also exist in my choice between i5-12400 and i5-12500. Hope to get a reasonable and detailed response. Thank you!
Sincerely Yours,
Zion Chen
DeividA_Intel
Hello ZionChen,
Thank you for posting on the Intel® communities. I understand you want more information about Multi-Format Codec Engines and how this improves the processor performance.
I will check this request internally to make sure I will provide you with accurate information and as soon as I have any details, I will let you know.
Thanks for your comprehension.
Deivid A.
DeividA_Intel
Hello ZionChen,
Thanks for your patience. I would like to let you know that having 2 Multi-format codecs as the other ones that have 1 will have a little improvement in performance, In simple words Multi-Format Codec Engines help with parallel decoding or encoding.
For example, when you play high-resolution videos/stream/code, it will exhaust engine 1, If you play another high-quality video at the same time, engine 2 will handle the task without disturbing the engine, for "single videos" it shouldn't have much difference, nevertheless should perform a little bit better.
If you have any other questions, just let me know.
Deivid A.
DeividA_Intel
Hello ZionChen,
This follow-up is to confirm if the information provided about "Multi-format codecs" was useful or if you have any other questions. Let me know if you need additional support.
Deivid A.
DeividA_Intel
Hello ZionChen,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
