17079 Discussions
Automatic overclock Fails
Joels84944
 I have a new Pc I built with a I7 14900KF, 32Gb of DDR4 Ram, a Nvidia RTX 4090. As soon as i startup your Intel Extreme Tuning Utility and try nd use the Automatic Overclock, it fails instantly
it says Manual Tuning Is currently active. How can I get the automatic Tuning to work?
DeividA_Intel
Hello Joels84944,
Thank you for posting on the Intel® communities. I understand you are having issues with the Intel® Extreme Tuning Utility (Intel® XTU).
In this case, Intel does not provide support or instructions for overclocking since altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of the motherboard and components for additional details.
However, you may find helpful information in the following link:
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
