Processors
14633 Discussions
Boot hangs because of PxSERR error (Core i7)
I have a MSI x58 Platinum mainboard with a Intel Core i7 processor and from to time to time it freezes during POST with AMI bios POST code - 423C. This happens right after the message that "4096MB OK" and before the detection of SATA/IDE drives.
When this happens, the only way to make the system run is to turn off the power (pressing Ctrl-Alt-Del of Reset would result in the same error) - after that the POST procedure finishes correctly and I don't experience any problems afterwards (system is rock-solid after POST completion).
I found in the documentation at http://www.intel.com/assets/pdf/specupdate/313075.pdf that this is a PxSERR error.
Is there a way to solve this?
