Anonymous
Not applicable
05-28-2020
08:41 AM
The IPDT is not designed to be run on processors this ancient. The Brand String test is always going to fail because the processors back then did not have brand strings! You can configure IPDT to skip this test, but I think you will run into problems with some of the other tests as well.
