Can I install a Core 2 Duo Mobile P8400 laptop Samsung RV510 socket P478
The P8400 is socket compatible with bga478 and pga478:
http://ark.intel.com/products/35569/Intel-Core2-Duo-Processor-P8400-3M-Cache-2_26-GHz-1066-MHz-FSB Intel® Core™2 Duo Processor P8400 (3M Cache, 2.26 GHz, 1066 MHz FSB) Specifications
If your laptop is bga478, the answer is no, as the processor is soldered to the motherboard.
If your laptop is pga478, the answer is maybe. While socket compatible, you have to check with Samsung to see if THEIR bios supports the p8400.
Doc
Doc
Hi killerman78,
The answer of Al Hill is very accurate, the best place to get the possible compatibility with this processor, would be with your OEM directly.
Samsung Support
http://www.samsung.com/us/support/ http://www.samsung.com/us/support/
Hellen.
