Some AVX512F intrinsic functions use __mmask8 masks, but 8-bit mask instructions like KMOVB and KANDB require AVX512DQ. How can I make sure the compiler uses 16-bit mask instructions (KMOVW, KANDW) and not 8-bit mask instructions when I have AVX512F but not AVX512DQ? I am writing generic code and I want to make sure the code works correctly in all compilers. For example:
__mmask8 a, b, c;
__m512i x, y, z;
a = b & c; // use KANDW, not KANDB
z = _mm512_mask_mov_epi64(x, a, y);
Or should I write:
__mmask16 a, b, c;
__m512i x, y, z;
z = _mm512_mask_mov_epi64(x, (__mmask8)a, y);
Sorry, this is a technical support forum for Intel processors. You need to repost your query in the Intel Developer Zone. Here is link to their forum: Intel Developer Zone forum. Unfortunately, I don't have the privileges that would allow me to move this query for you.
