17078 Discussions
Chipset Driver (Intel)
dkimclint
Hi guys! Why I can't update my Chipset Driver (Intel)? I'm using Acer Nitro V15, Windows 11. Thank You.image_2024-04-16_212722705.pngimage_2024-04-16_212848978.png
AlHill
Go to Acer and get the chipset device software for your device.  If it does not install, ask acer for assistance.
[If you find any Intel driver you might need, download and save it now.]
n_scott_pearson
I suggest that you clean install the package. Here is the process:
  1. If you haven't already, download the Chipset Device Software package in ZIP file form.
  2. Extract the contents of this package to a temporary folder.
  3. Open a Command or PowerShell Window and make this temporary folder the current folder.
  4. Run command ".\SetupChipset.exe -overall".
  5. Reboot.
If the installer is not available in ZIP file form, using a tool like 7-ZIP, attempt to open the executable as an archive and, if you can, extract the files from there.
Hope this helps,
