Processors
14590 Discussions
Coffee Lake PCIe Lanes
So i was kinda confused about the new Coffee lake series. Because on the intel site it states that the 8700k only supports 16 PCIe lanes. But what if i wanna use 2 or more GPUs which each require 16 lanes. i heard about the fact that the mainboard should provide 24 extra lanes but is the performance still equal to a CPU with lets say 40 lanes?
Thanks for the help
Hello Paylam,
I understand you are having some questions about the maximum PCIe lanes that our Coffee Lake processors can provide.
Let me share with you that the lanes that a processor provides are dedicated to graphics so if you install two graphic cards and each one will require 16 lanes the processor might only recognize one. If you are looking for a configuration with two graphic cards I will suggest you to check our Intel® Core™ X-series Processors which will allow more than 16 PCIe lanes. Please find here the link to look for these processors: https://ark.intel.com/products/series/123588/Intel-Core-X-series-Processors https://ark.intel.com/products/series/123588/Intel-Core-X-series-Processors
In the other hand, indeed the motherboard should provide PCIe lanes nonetheless, they will not be able to support graphics and, the purpose of those will be for any other task like USB 3.0 or Wireless card.
I hope this answers your questions.
Antony S.
Leon_Merts
New Contributor II
Hi Paylam,
In addition of the previous reply, you can use 2 (or more) video cards in a i7-8700K system.
Just know that the x16 PCIe slots you would be using will be running in a x8 PCIe mode and if more then 2 slots (PCIe 3.0) are used they will be running in a x4 PCIe mode.
This should also be mentioned in your motherboard manual and which slots to use (Mostly from close to the CPU and downwards depending on how it is fitted in it's case.
As Intel mentioned the Core-X CPU's have have enough PCIe lanes (44) to make full use of the video cards (max. 2 = 32 lanes = 12 lanes free) bandwidth / speed.
Leon Merts
