Core 2 Duo E8400
TLeon2
Will there be microcode updates for the E8400 C0 stepping CPU as I have seen a list provided by Intel that Core 2 processors are affected by Spectre?
Banger
Hello, Banger
I understand you would like to know more information about the Spectre and Meltdown issue. Allow me to help you regarding this inquiry you have.
We are still working hard to provide a solution for this issue. Intel and other companies have begun providing software and firmware updates to mitigate these exploits. You can also check with your operating system vendors if there is any update available.
Please find more information about this issue below:
Antony S.
TLeon2
I could be blind but I cant find a list of products on the page link you give?
Hello, Banger.
Please double check this link: http://www.intel.com/content/www/us/en/architecture-and-technology/facts-about-side-channel-analysis-and-intel-products.html the webpage there is a section that says Impacted Intel® Platforms, over there you should be able to verify this information.
Antony S.
TLeon2
Many thanks but what generation is a Core 2 Duo processor is it part of the 2nd generation of Core products?
n_scott_pearson
No, the Core 2 Duo E8400 is actually part of the processor generations that preceded the First Generation Intel Core processors.
TLeon2
So at present Core 2 Duo isn't listed as affected?
n_scott_pearson
ble2
If I'm using that cpu core 2 duo, would like to upgrade to core i3 is compatible with the old main ? now, i running some thing to view my site: http://giaythethaonamtphcm.com
n_scott_pearson
Not a chance. You can only upgrade to processors in the same family, compatible with the socket and supported by the board's BIOS. For a list of the processors that you can upgrade to, you need to contact the manufacturer of your motherboard.
My personal opinion? Dump this ancient crap and get something much more modern.
