16880 Discussions
Cpu Peaks 100% usage i5-1335U
luis200hr
When I start my laptop I see that the windows task manager performance graph is at 100% and start to drop to normal, but then it starts to reach 100% again. I have checked Arc Control in the CPU performance section but I never see it reach 100% cpu usage. The consumption information differs a lot between what arc control and task manager give me. These consumption peaks at 100% cause me fps drop, a slight freeze in programs.
when I bought it I didn't have any of these problems but after 2 months of use I started to notice them.
What can I do to solve it?
Laptop: HP 15-fd0000
CPU: Intel core i5 1335U
Graphic: Intel Iris Xe Graphics
RAM: 32 GB DRR4  3200Mhz
Mike_Intel
Hello luis200hr,
Before we proceed, let me gather more details about the issue:
  1. Is there a particular application that causes this or the system is in idle?
  2. Did you change any settings or added a program before you start having this issue?
  3. Did you overclock your processor?
  4. Did you check the task manager if there is an app that causing the processor to this this?
Michael L.
Mike_Intel
Hello luis200hr,
Michael L.
Mike_Intel
Hello luis200hr,
I am sending another follow up on the information that I requested.
Michael L.
