- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
What temperature can the Intel Core i5-3470 processor support without reducing its useful life and that of the motherboard where it is installed? Does this processor have a system to shut it down when it reaches a certain temperature without compromising its and the motherboard's useful life?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Your processor's Tcontrol temperature will be somewhere in the vicinity of 85°C. Having short-term spikes above this temperature are also perfectly fine. Sustained higher temperatures will eventually cause damage both in the processor and surrounding circuitry.
Intel's guidance for this older processor generation was that, should the processor's temperature be at or above its Tcontrol temperature, the processor cooling solution should have all fans (pumps, etc.) at their full speed (100% duty cycle). If temperatures continue to rise, the chassis fan(s) should be increasing their speed in order to assist the processor cooling solution.
When temperatures reach the processor's Maximum Junction Temperature (Tjmax, in the vicinity of 100°C), the processor will automatically throttle its performance, by reducing clocks, to protect the processor.
If the temperature continues to rise and reaches the processor's Therm-Trip temperature (Intel doesn't publish how far above Tjmax this is), the processor will shut down the system.
It is important to mention that this description is specific to these older processors and only approximates the workings of later generation processors.
Hope this helps.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have this processor and it was hot 84C or 86C going to 90C and it was necessary to replace the cooler for the temperature to return to 41C, was this period that this processor model operated at this high temperature enough to reduce the useful life of it and the motherboard? I don't know how many days or months it operated at that temperature but recently I looked at aida64 and it was high
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
No, it should not have affected it much. But (there's always a 'but'), understand that you are well beyond the typical lifetime for these processors already. It was manufactured in 2012, after all.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hope this helps,
