17536 Discussions
Dynamic Platform and Thermal Framework
slojure
I am new here  (i didnt know where to post my question) and have problem with Dynamic Platform and Thermal Framework. My laptop (ASUSTeK COMPUTER INC. X751LX)
going into sleep mode randomly even if in use. It happens some days and not everyday. Can someone please help, what it is all about?
Specs of error:
Intel(R) Dynamic Platform and Thermal Framework : ESIF(8.3.10207.5567) TYPE: ERROR MODULE: DPTF TIME 173438867 ms
DPTF Build Version: 8.3.10207.5567
DPTF Build Date: Nov 2 2017 14:28:00
Source File: ..\..\..\..\Sources\Policies\ConfigTdpPolicy\ConfigTdpPolicy.cpp @ line 194
Executing Function: ConfigTdpPolicy::onDomainPowerControlCapabilityChanged
Message:
Source File: ..\..\..\Sources\Manager\EsifServices.cpp @ line 540
Executing Function: EsifServices::primitiveExecuteSetAsTimeInMilliseconds
Message: Error returned from ESIF services interface function call
Participant: TCPU [0]
Domain: PKG [0]
ESIF Primitive: SET_RAPL_POWER_LIMIT_TIME_WINDOW [340]
ESIF Instance: 0
ESIF Return Code: ESIF_E_PRIMITIVE_NOT_FOUND_IN_DSP [2404]
Domain: PKG [0]
Policy: ConfigTDP Policy [0]
David_G_Intel
Hello slojure
Thank you for posting on the Intel️® communities. Please share with us the Intel® System Support Utility (Intel® SSU) results:
David G
slojure
Here are the  Intel® System Support Utility (Intel® SSU) results:
David_G_Intel
After checking the information provided we noticed that you're not running the latest BIOS version. Please contact the system manufacturer for BIOS and firmware updates. Let us know if the issue persists after the updates.
David G
slojure
But Intel Driver Support Assistant says, No supported driver or software updates are avaliable for your system.
Where can i  download latest BIOS version for my laptop?
AlHill
Asus laptop means Asus bios.   That is where you go for your bios.
[Windows 11 is the new Vista]
slojure
I downloaded BIOS file from Asus page, but when i start WinFlash, i get: low battery message. I have AC/DC pluged in...can i force install?
AlHill
For help with the ASUS bios, contact ASUS.   There is no help provided here for their bios.
HalfPastTwo
Hello Community
I've a similar problem on an Asus UX305 - Device Manager showing an error for the Intel Dynamic Platform & Thermal Framework driver:
Driver Management has concluded the process to add Service DptfManager for Device Instance ID ACPI\INT3400\2&DABA3FF&1 with the following status: 0.
This error appears to date to some automatic update being applied in March 2023 (I think!).
The driver installed dates from 2015 and is version 604.10146.2651.1559.
Details from the Support Sys Utility Attached.
Any suggestions on where to obtain an updated driver would be much appreciated!
H
MathiasRolf
Dear Intel Support Team,
I have finally upgraded my ASUS UX550VD to Windows 11. There are some chips on the motherboard of the notebook that Windows 11 did not recognise:
  • Intel(R) Dynamic Platform and Thermal Framework Processor Participant drivers / ASUSTeK UX550VD
    VEN_8086&DEV_1903&SUBSYS_19701043&REV_05
  • Intel(R) 100 Series/C230 Series Chipset Family PMC - A121 drivers / ASUSTeK UX550VD
    VEN8086&DEV_A121&SUBSYS_19701043&REV_31
  • Intel(R) Management Engine Interface Driver for ASUSTeK - UX550VD
    VEN_8086&DEV_A13A&SUBSYS_19701043&REV_31
  • Intel(R) Dynamic Platform and Thermal Framework Generic Participant
    VEN_INT&DEV_3403
Attached you find the results of my scan with SSU Scan.
ASUS has not published any drivers for Windows 11 for these hardware components.
Is there any way to get Windows 11 drivers for these components via Intel?
Thanks for a short answer in advance.
Salut,
  Mathias
AlHill
@MathiasRolf    You do realize that your processor is not supported by windows 11, correct?
[W10 is today's XP ]
MathiasRolf
Hello AlHill,
thanks for your reply.
I am aware that this is a rather "aged" notebook. But it does what I need off it and so I thought I better ask here.
The notebook is working and I can watch the heat (e.g. use fan on stand) and the battery load myself.
In case someone else has found a solution, please let me know.
Salut,
  Mathias
AlHill
Did you perform an upgrade from W10, or a fresh install?
If you did an upgrade, you should not have these problems.
MathiasRolf
Hello AlHill,
it was a fresh install since I also wanted to re-arrange the partitions and use the drive more effectively.
I was really hoping Windows 11 would detect the hardware in the notebook better than it did.
I do still have the drivers for Windows 10 that came with the notebook in 2018. But they are of no use.
Salut,
  Mathias
AlHill
There is your problem.
You need to go to the asustek site and download their software (chipset, ME, etc) for windows 10 to correct those issues.
MathiasRolf
Thanks, AlHill.
I will do this in the next 2 days and report back.
Salut,
  Mathias
