Processors
14588 Discussions
E5-2618L V3 TpmC Data.
dkwon2
I want to use a E5-2618L v3 CPU.
The data on the performance required prior to use.
If you would like to ask tpmC data.
CPU: E5-2618L V3
memory: DDR4 2133MHz 32GB
Hi Daejoongkwon,
This information is what I could find according to what I understood; let me know if it helps you in your search.
Intel® Xeon® Processor E5 Family Solutions
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-solutions.html http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-solutions.html
In this link you will find the Intel® Data Center Performance, Features, Benefits and others:
http://www.intel.com/content/www/us/en/benchmarks/intel-data-center-performance.html http://www.intel.com/content/www/us/en/benchmarks/intel-data-center-performance.html
High Performance Computing Benchmarks:
Intel® Xeon® Processor E5-2600 v3 HPC Matrix Multiplication:
http://www.intel.com/content/www/us/en/benchmarks/server/xeon-e5-2600-v3/xeon-e5-2600-v3-linpack.html http://www.intel.com/content/www/us/en/benchmarks/server/xeon-e5-2600-v3/xeon-e5-2600-v3-linpack.html
Intel® Xeon® Processor E5-2600 v3 HPC MPI2007 Performance
http://www.intel.com/content/www/us/en/benchmarks/server/xeon-e5-2600-v3/xeon-e5-2600-v3-specmpi-base2007.html http://www.intel.com/content/www/us/en/benchmarks/server/xeon-e5-2600-v3/xeon-e5-2600-v3-specmpi-base2007.html
Product and Performance Information (TPM)
Results based on Intel internal measurements, see Tests/Configuration below.
Software and workloads used in performance tests may have been optimized for performance only on Intel microprocessors. Performance tests, such as SYSmark and MobileMark, are measured using specific computer systems, components, software, operations and functions.
Test/Configurations:
Up to 21% on performance gain claim based on OLTP brokerage and warehouse workloads:
* Brokerage Firm OLTP: 1-Node, 2 x Intel® Xeon® Processor E5-2699 v3 with 512 GB Total Memory on Windows Server* 2012 R2 Datacenter using SQL Server 2012. Data Source: Request Number: 402, Benchmark: TPC Benchmark* E (TPC-E), Score: 3576 vs. 1-Node, 2 x Intel® Xeon® Processor E5-2699 v4 with 512 GB Total Memory on Windows Server* 2012 R2 Standard using SQL Server 2014. Data Source: Request Number: 1640, Benchmark: TPC Benchmark* E (TPC-E), Score: 4373 Higher is better.
*Warehouse OLTP: 1-Node, 2 x Intel® Xeon® Processor E5-2699 v3 with 512 GB Total emory on Red Hat Enterprise Linux* 6.5 kernel 2.6.32-431 using leading database vendor. Data Source: Request Number: 235, Score: 2,760,000 tpm vs.1-Node, 2 x Intel® Xeon® Processor E5-2699 v4 with 512 GB Total Memory on Red Hat Enterprise Linux* 7.1 kernel 3.10.0-229 using leading database vendor. Data Source: Request Number: 1646, Score: 3,143,848 Higher is better.
Up to 29% performance gain claim on HammerDB workload:
*HammerDB: 1-Node, 2 x Intel® Xeon® Processor E5-2699 v3 with 384 GB Total Memory on Oracle Linux* 6.5 using a leading database vendor using 800 warehouses. Data Source: Request Number: 46, Benchmark: HammerDB, Score: 3,184,852 vs. 1-Node, 2 x Intel® Xeon® Processor E5-2699 v4 with 384 GB Total Memory on Red Hat Enterprise Linux* 7.1 kernel 3.10.0-229 using leading database vendor (including database and grid) with 800 warehouses, HammerDB 2.18. Data Source: Request Number: 1645, Benchmark: HammerDB, Score: 4,135,676 Higher is better
Up to 31% performance gain based on Intel Optimized MP LINPACK (MPL) workload, running Red Hat Enterprise Linux* (RHEL):
*LINPACK: 1-Node, 2 x Intel® Xeon® Processor E5-2699 v3 with 64 GB Total Memory on CentOS* using MP_LINPACK 11.3.1 (Composer XE 2016 U1) @ 80,000 problem size. Data Source: Request Number: 1636, Benchmark: Intel® Optimized MP LINPACK, Score: 1096 vs.1-Node, 2 x Intel® Xeon® Processor E5-2699 v4 with 64 GB Total Memory on Red Hat Enterprise Linux* 7.0 kernel 3.10.0-123 using MP_LINPACK 11.3.1 (Composer XE 2016 U1). Data Source: Request Number: 1636, Benchmark: Intel® Optimized MP LINPACK, Score: 1446 Higher is better
Up to 2.7x more VMs based on Intel Virtualized Consolidation workload estimates comparing 2x Intel Xeon processor E5-2690 (8C) supporting 21 VMs to 2x Intel Xeon processor E5-2699 v4 (22C) supporting 58 VMs
*1-Node, 2 x Intel® Xeon® Processor E5-2690 with 256 GB Total Memory on VMware ESXi* 6.0 GA. Data Source: Request Number: 1718 to 1-Node, 2 x Intel® Xeon® Processor E5-2699 v4 with 512 GB Total Memory on VMware ESXi* 6.0 Update 1 build 3029758. Data Source: Request Number: 1637
Hellen.
Hi Daejoongkwon,
I am following your case. Let me know if you need further assistance.
Mike C
