17084 Discussions
Errors when starting the system (CPU)
Qilin
May run forever in BIOS, but the system won't start. What could be with the processor? The computer is not mine
AlHill
All I see is an unsupported Intel processor on an Asus motherboard, some mismatched and mixed speed crucial and kingston memory, and indications of a hardware error.
Your friend has enough problems that requires him/her to contact Asus support.
AlHill
The CPU supported by your friend's motherboard is E5-2699-v3, not the E5-2673 v4.
https://www.asus.com/support/CPU/1/42/3/2/qCCN4VASDw933uL6/C20140909142535/
As you can see in the above link, you and your friend have problems with your configuration, using an incorrect processor.
AlHill
Also, look at this page:
https://www.asus.com/uk/supportonly/X99-S/HelpDesk_CPU/
You will not find the 2673 v4 listed.  That should be enough information for you and your friend.
