17083 Discussions
High core temperatures
MSega2
Hello
I have one Samsung RF511-SD3, which is equipped with one i7-2670QM processor.
The problem is: core temperatures are always higher than what it should, at least compared to the values searched.
It's around 60-65ºC while idle and go up to 95ºC when running a game. Though they are acceptable to the limit specified (100ºC), I noticed that even while using low CPU the core temperatures still raise a lot.
While searching for a solution, I found the Intel program: Intel Processor Diagnostic Tool. The result was:
As far as I know, all the recommended settings for this test were applied according to the same Intel page where the program was downloaded.
The reasons why I think it has any problem are mainly due to the idle temperature and when using low CPU and still having high temperatures.
I appreciate any help.
Edit:
Running *\Intel Corporation\Intel Processor Diagnostic Tool 64bit\CPUFreq.exe I got the following diagnostic:
CPU Frequency Test
Module Version: 1.0.14.64b.W
Start Time: Thu Feb 04 12:01:53 2016
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
Expected CPU Frequency: 2.20
Detected CPU Frequency: 2.2
Expected Base Clock: 100
Detected Base Clock: 100
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Thu Feb 04 12:01:55 2016
Total Time: seconds: 2
Another fact noticed is when using the laptop connected and with the battery attached: after some hour doing heavy tasks, the battery is still at 99-100% of charge, but after unplug the energy cable the computer shut down. I found out that it was some kind of imbalance among the battery cells and it happens merely due to high usage.
Amy_C_Intel
Hello, Klein:
Could you please attach the report for the Intel Processor Diagnostic Tool?
MSega2
Amy_Intel escreveu:
Hello, Klein:
Sure.
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 05/02/2016 14:27:45
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Fri Feb 05 14:27:45 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
End Time: Fri Feb 05 14:27:46 2016
Total Time: seconds: 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Fri Feb 05 14:27:46 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 21 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Information: Intel64 Family 6 Model 42 Stepping 7
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 8 GB
Operating System: Microsoft Windows 10 Pro 64 bits
Graphics Information: NVIDIA GeForce GT 540M
System Product: RF511/RF411/RF711
System BIOS: 17HX.M045.20121127.SSH
System Serial Number: HNLP9QBC400818
--- IPDT64 - End Time: 05/02/2016 14:27:46
--- IPDT64 - Result: Fail
Amy_C_Intel
Please try to set power options in Windows® 10 to "Balanced(recommended)" and run the test one more time, also make sure that in "Chance advanced power settings" you have the following;
MSega2
Hello Amy_Intel
The test result was done with these settings that you advised.
Edit: accidentally I posted all the test results done. I edited the last post and now there is only one result done with the advised settings.
Amy_C_Intel
Have you contacted Samsung Support in regard to this matter? Normally, I would recommend you to contact us in order to check the replacement options but this is an OEM system and it is possible that your computer manufacturer can provide with more troubleshooting steps.
MSega2
I did contacted Samsung Support in the past and everything they said was: "once the temperature isn't above 100ºC, it's normal".
I will try another contact with Samsung Support and update this topic.
Amy_C_Intel
