16962 Discussions
I've problems to configure 3200mhz memory with a i7 8700 (non K)
chrismartz84
I have an i7 8700 processor, the motherboard is an Asus B360-H Gaming and supports a variety of speeds in RAM. I have mounted 2x8GB to 3200 Mhz, however the CPU limits it to 2666mhz. I would like to know why? Call Asus and the problem is not theirs, change the BIOS and still persists. But I've read in other forums that the problem is with the processor. I need help please.
Thank you!
CSpot
I would recommend you to not to get involved in such solutions, and get advice from a good hardware engineer. They would help you in a better way.
chrismartz84
Well, in this case could you give me a contact with an intel engineer to solve this problem?
Amy_C_Intel1
That is because the supported memory type for this processor is DDR4-2666. Check the 'Memory Types' in the following link: https://ark.intel.com/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4-60-GHz- Amy C Intel Customer Support Technician Under Contract to Intel Corporation
