Processors
14734 Discussions
IPDT requires old VC++2010 Redistributable Package
I downloaded "IPDT Installer 32Bit 1.42.0.0-13-9.exe"(latest) and run it. But that requires "VC++2010 Redistributable Package".
I already installed "VC++2010 Redistributable Package SP1",so IPDT installer fail to install "VC++2010 Redistributable Package" and failed to install IPDT...
Prease UPDATE to "Microsoft Visual C++ 2010 SP1 Redistributable Package"
http://www.microsoft.com/download/en/details.aspx?id=8328 http://www.microsoft.com/download/en/details.aspx?id=8328
Adolfo_S_Intel2
Try running the tool on another system, if it works fine, then I would suggest trying a clean installation of the operating system.
MZisl1
Adolfo, you are a funny person! Reinstall the OS because this app has an outdated prereq, that's a good one!
I did find a workaround to it, using 7-Zip extract the contents of IPDT Installer 64Bit 1.17.0.0-10-9.exe to a folder and run IPDT64_Install.msi alone. You will skip the outdated prereq check and be testing in no time.
