IPDT test fail
RSing20
I had to replace my hard drive and install a new copy of windows and reinstall all the drivers. Since i have done that my IPDT is failing again and again. The tests that are failing are Prime Number, floating Point & Math. I have updated the drivers to the latest version. Please let me know what can i do here.
My processor is Intel i7 2630QM.
Laptop is HP Pavilion Dv6 6121TX.
I have attached the test results for your reference.
Hello Ranabegins,
I understand that your processor is not passing three different tests done.
Regarding this, I would like you to start by re-installing the Intel ® Processor Diagnostic Tool completely. By completely I mean first uninstall it by going to the programs under your settings and after it is removed re-download it and re-install it. You can download it from the link below:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel ® Processor Diagnostic Tool
Once it is installed, please run a new diagnostic/test and then attach the results to the thread so I can review it.
David V
Hello Ranabegins,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
