Processors
14591 Discussions
Intel 7820x Core CPU BSOD's
PKrza
Configuration
Intel i7 7820x + MSI SLI PLUS x299. Last BIOS and drivers.
My problem
When Intel Turbo Bost is activated in BIOS, Photoshop CC 2017, Bridge CC 2017, After Effects CC 2017 crashes imidietly with BSOD.
When I disable Turbo Boost Max 3.0 nothing changes. It is impossible to deinstall Turbo Boost Max 3.0.
But when i deactivate Turbo Boost in BIOS Adobe program works perfect.
Other programs works normal in Turbo Boost.
Any solution for this problem ?
sshat
Thats awesome! Thanks for the update @Klevunin! So I assume you can run your turbo boost intel software now?
KLevu
Yes, absolutely right. I have BIOS settings standard. Turboost works and works photoshop.
BIOS 0802 ASUS X299-PRIME-A Update Intel X-series CPU (6-core and above) microcode.
BCham3
Can confirm. I have updated my Asus x299 Strix E Gaming Mobo and I can use Turbo Boost with Adobe CC with no crashes!
sshat
wow, thank you Intel and Asus. I can now rock my dual brushes and mixer brushes at obsecenely fast speeds. No lag. This is kinda wild. I've never experienced this before. this is amazing!
Hi fauntailjabuti,
Thank you for confirming this issue is solved by updating the motherboard BIOS, I am glad this is working for you now.
Allan J.
KLevu
I have a BSOD on the last bios i7-7820x
on the old version of the BIOS, I received the BSD only in Photoshop
after the BIOS update, I stopped receiving the BSOD in Photoshop
But today I got the BSD only in the Chrome browser
https://yadi.sk/d/IK2fo2UN3NM3fF https://yadi.sk/d/IK2fo2UN3NM3fF - 093017-12203-01.dmp
0: kd> !analyze -v
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: ffff8b09c13a2800, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8029c3d387a, address which referenced memory
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.15063.608 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER: System manufacturer
SYSTEM_PRODUCT_NAME: System Product Name
SYSTEM_SKU: SKU
SYSTEM_VERSION: System Version
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: 0802
BIOS_DATE: 09/06/2017
BASEBOARD_MANUFACTURER: ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT: PRIME X299-A
BASEBOARD_VERSION: Rev 1.xx
DUMP_TYPE: 2
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_P1: ffff8b09c13a2800
BUGCHECK_P2: 2
BUGCHECK_P3: 1
BUGCHECK_P4: fffff8029c3d387a
WRITE_ADDRESS: fffff8029c5ec358: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
ffff8b09c13a2800
CURRENT_IRQL: 2
FAULTING_IP:
nt!KeQueryTotalCycleTimeThread+ae49a
fffff802`9c3d387a f0480fba6b4000 lock bts qword ptr [rbx+40h],0
CPU_COUNT: 10
CPU_MHZ: e10
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 55
CPU_STEPPING: 4
CPU_MICROCODE: 6,55,4,0 (F,M,S,R) SIG: 200002B'00000000 (cache) 200002B'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: System
ANALYSIS_SESSION_HOST: SPY
ANALYSIS_SESSION_TIME: 09-30-2017 10:45:13.0684
ANALYSIS_VERSION: 10.0.15063.468 amd64fre
TRAP_FRAME: ffffa201ad8fbea0 -- (.trap 0xffffa201ad8fbea0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffff8b09b535b040 rbx=0000000000000000 rcx=ffff8b09c13a27c0
rdx=ffffa201ad8fc220 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8029c3d387a rsp=ffffa201ad8fc030 rbp=ffffa201ad8fc130
r8=ffff8b09b9c42860 r9=0000000000000001 r10=ffffa201ad8fbb70
r11=ffffa201ad8fc140 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!KeQueryTotalCycleTimeThread+0xae49a:
fffff802`9c3d387a f0480fba6b4000 lock bts qword ptr [rbx+40h],0 ds:00000000`00000040=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8029c3828a9 to fffff8029c377580
STACK_TEXT:
ffffa201`ad8fbd58 fffff802`9c3828a9 : 00000000`0000000a ffff8b09`c13a2800 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
ffffa201`ad8fbd60 fffff802`9c380e7d : ffffcb0b`d3c91e00 ffffcb0b`c9815040 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffffa201`ad8fbea0 fffff802`9c3d387a : 00000000`00000000 00000000`000000f2 00000000`00000000 00000000`000000f2 : nt!KiPageFault+0x23d
ffffa201`ad8fc030 fffff805`f3546612 : 00200045`00520052 ffffcb0b`daccbad4 ffff8b09`b535b040 fffff805`f3550330 : nt!KeQueryTotalCycleTimeThread+0xae49a
ffffa201`ad8fc160 00200045`00520052 : ffffcb0b`daccbad4 ffff8b09`b535b040 fffff805`f3550330 00000000`00000000 : IntelNit+0x6612
ffffa201`ad8fc168 ffffcb0b`daccbad4 : ffff8b09`b535b040 fffff805`f3550330 00000000`00000000 00000000`00000000 : 0x00200045`00520052
ffffa201`ad8fc170 ffff8b09`b535b040 : fffff805`f3550330 00000000`00000000 00000000`00000000 80000000`c000000d : 0xffffcb0b`daccbad4
ffffa201`ad8fc178 fffff805`f3550330 : 00000000`00000000 00000000`00000000 80000000`c000000d 00000000`00000000 : 0xffff8b09`b535b040
ffffa201`ad8fc180 00000000`00000000 : 00000000`00000000 80000000`c000000d 00000000`00000000 00000000`00000000 : IntelNit+0x10330
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: a6f5d20972abe84fd01ccdfedd6ebeb3821616f5
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 8f8959082d43e4a23e4a1325e0444839358036e2
THREAD_SHA1_HASH_MOD: ca2516a6fc4100b4741d669c0e97fa276eac24b6
FOLLOWUP_IP:
IntelNit+6612
fffff805`f3546612 ?? ???
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: IntelNit+6612
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: IntelNit
IMAGE_NAME: IntelNit.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 593ba6bd
BUCKET_ID_FUNC_OFFSET: 6612
FAILURE_BUCKET_ID: AV_IntelNit!unknown_function
PRIMARY_PROBLEM_CLASS: AV_IntelNit!unknown_function
TARGET_TIME: 2017-09-30T07:39:25.000Z
OSBUILD: 15063
OSSERVICEPACK: 608
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
KLevu
https://yadi.sk/d/uJKuWG2u3NZnch https://yadi.sk/d/uJKuWG2u3NZnch
I again received the BSOD
This happens when watching a video on YouTube
The system is cold and unloaded
When will it be fixed or is it a problem of the processor and it needs to be changed?
Hi klevunin,
Thank you for the updates however, I do not think this is a processor issue. You are getting BSOD with Chrome and YouTube, this means the Internet browser. You may have an issue with the operating system.
Allan J.
Hi klevunin,
I was wondering if you were able to test or run system restore or even reload operating system for registry problems?
Allan J.
KLevu
I have a suspicion about virtual machine virtualbox I created a machine with a working environment, for which I allocated 2 cores. Due to the fact that the 7820x is quite powerful, it does not prevent me from disconnecting it when I do not even work with it. I also do not turn off the computer. He falls asleep himself, and I wake him up. When he wakes up, the virtual machine also wakes up. And I had a few BSOD at that moment. Now I'm disconnecting the virtualbox when I stop working with it, after that there was no problem.
Mvand4
There is no need for AVX offset or disable turbo boost.
the truth here is that motherboard vendors are standard overclocking these cpu's. (don't know if they all do it, but MSI for example does) For the 7820x it should standard overclock all cores to 4GHZ. with a turbo of 4.5GHZ
The problem is that a fair amount of 7820x cpu's cant run stable on these clockspeeds because most mainboards set the auto vcore setting too low. So not enough juice to feed the cpu resulting in BSOD such as WHEA uncorrectable.
So until mainboard vendors come up with a better bios version. You have to manually set a Vcore value to make it stable.
You can start of setting the Vcore at a basic 1.2V and look if it runs stable. (it should be stable at 1.2V)
If it does you can lower the vcore with small steps (0.005V) until it becomes unstable. Recommended is setting it to adaptive mode so it does not run 1.2v trough the CPU all the time.
You can choose the CPU frequencies to your need but keep in mind that higher freqs needs higher vcore voltages and raising temps.
sshat
Hey thanks @Mark81!
This was tremendously helpful and an immense insight. I have a system I put a lot of money into with what I thought were top grade parts, but was feeling like something was not right. After all, I updated to latest bios, combed forums and pretty much everything else I could read about. Then your valuable post came through and I can't thank you enough. The system is really purring now.
I hope you reap a lot of karma points for your help!
Faunt
Mvand4
Hey @Faunt
Great too hear it worked for you! Can you tell me which motherboard you have? And at what voltage and frequency are you ended up with?
Thnx, Mark
sshat
Hi mark,
Increasing the voltage has seemed to be a step in the right direction for sure. I can see the whole machine runs more stably.
it seems to have worked for me and solved some issues, yet others persist. i don't understand the abnormal behavior. Seems like the cpu is working too hard to relatively simple tasks or no tasks at all. I'm going to migrate this conversation to appropriate channels.
heres what I'm running:
Voltage: 1.25 vo
CPU: I7-7820X @ 3.6ghz
M/B: Asus Prime X299 Deluxe
RAM: G.SKILL, TridentZ, Series 64GB (4x16GB sticks) DDR4, SDRAM 3600
SSD: INTEL SSD 750 Series Connected through PCIE
VGA: Asus GeForce 1080Ti
CPU Cooler: Corsair H100 V2 Extreme
PSU: Corsair RM 1000i
Mvand4
wow 1.25v is way overkill for only 3.6GHZ. You can at least run 4.6 or 4.7GHZ with that voltage.
That said. Can you check at which setting your energy power profile is set to?. it should been set to balanced.
JSima1
Hi Mark, did you found that solution on Puget System Website (https://www.pugetsystems.com/labs/support-hardware/WHEA-UNCORRECTABLE-ERROR-on-Gigabyte-x299-and-Skylake-X-SOLVED-1042/ https://www.pugetsystems.com/labs/support-hardware/WHEA-UNCORRECTABLE-ERROR-on-Gigabyte-x299-and-Skylake-X-SOLVED-1042/ _?
I see many posts here about the exact same problem and Intel doesn't seem to be aware of the problem and solution.
So I made that post and I hope Intel can send a note to all their customers about this, I lost so much time with that problem and the solution is so easy but we just need to know abou it!:
In my case I also wanted to overclock a bit more and when doing so the BSOD were back so I ended up also using the avx offset and now I have no more blue screen. Or should I try to increase the voltage from 1200mV instead of avx offset?
My system:
Alienware Area 51 R4
i9-7980XE
windows 10 1709
64GB ram 2666
water cooling
2 x 1080ti zotac mini
os on 512GB samsun evo pro on board m.2
2x samsung evo pro 1TB m.2 in raid 0 on Highpoint rocket raid pcie card
1500W psu
Mvand4
yes that puget article was one of my sources , Strob.
You should only AVX offset for temperature reasons and not BSOD's. I think you should raise your vcore voltage a bit. What freqs are you on?? Mine cant get past 4.7GHZ without delidding. And i have an AVX offset only for AVX512
JSima1
Why did you set only avx512 (what's the difference between both avx?)
Here is what my frequencies look when I am rendering. I find weird that not all my core seems to be affected by turbo.I set those settings:
OC\Mail Box Configuration\Processor
Core Max OC ratio 80
OC\CPU Power Management Configuration
Turbo Modo Enabled
Long duration power limit: 240
Long duration power limit: 1
Short duration power limit: 250
Short duration power limit: 1
Core Ratio Limit 1: 42
Core count number: 18
OC\Overvoltage
vccin voltage: 1830
memory voltage: 1200
And both avx offset to 5
sshat
Just curious, Strob, but what kind of temperatures are you seeing when rendering? I guess I'm asking because mine skyrocket to max temperatures and its doesn't seem right?
JSima1
It stays pretty cool (50 to 60 depending on the core)
Last night I had another blue screen during rendering. So I will try without the AVX offset and increase the voltage a bit.
Mvand4
Hi strob,
AVX512 is the most demanding instruction your CPU will ever face. System power draw and temps will go trough the roof. Thats why i set a avx512 offset. With my 8 core @ 4.7GHZ, temps are reaching very fast 90C
I think your cpu is heavily throttling. 4.6 GHZ on a 18 core is way to high. Especially on a non delidded CPU. What motherboard do you have??
You can check if your cpu is throttling with aida64 and choose system stability check.
