Intel Ipp Library
AlperenB
I am using VxWorks ipp library (9.0.4.038) but I need object files (.o) of this library instead of .a files. Can you provide objects files of ipp library version 9?
ShanmukhS_Intel
Hi Alperen,
Thank you for posting on Intel Communities.
Could you please confirm if you mean the shared object files and let us know any ".a" or ".so" file as an example?
Shanmukh.SS
AlperenB
Yes I mean the static object files of ipp library, exactly. For example, under ipp_vxworks9.0.4.038 folder I have includes such as ipp.h, ippvm.h etc. and archive files such as libippcc.a, libipps.a. What I need is the static object files of following libraries:
-libippcc.a
-libippch.a
-libippcore.a
-libippcp.a
-libippcv.a
-libippdc.a
-libippi.a
-libipps.a
-libippvm.a
I would be grateful if you could help me. Thanks.
ShanmukhS_Intel
Hi Alperen,
Could you please let us know if you have downloaded the IPP library for your environment?
Shanmukh.SS
AlperenB
I have IPP Library for Vxworks environment (version 9.0.4.038), but these files are in archive file (.a) format.
ShanmukhS_Intel
Could you please download Intel oneAPI for your environment with which you will be getting .so files as well under below path.
/opt/intel/oneapi/mkl/latest/lib/intel64
Kindly let us know if you are not able to get these files.
Shanmukh.SS
AlperenB
I have downloaded oneAPI but it is only available for Windows, Linux and macOS. I need these library files that I mentioned for VxWorks environment and could not find on your website.
ShanmukhS_Intel
Please find the list of supported Operating Systems for Intel® Integrated Performance Primitives System Requirements for Intel® oneAPI Base Toolkit.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-intel-integrated-performance-primitives-system-requirements.html
Shanmukh.SS
ShanmukhS_Intel
Reminder:
Has the information provided helped? Please let us know if you need any other information.
Shanmukh.SS
AlperenB
Unfortunately it has not. VxWorks is not in the list of supported Operating Systems for Intel® Integrated Performance Primitives System Requirements for Intel® oneAPI Base Toolkit, I guess you no longer support VxWorks. I have VxWorks ipp library version 9.0.4.038 which seems not available for download on your website, so my question was can you provide a solution because I could not able to download IPP for VxWorks on your website.
ShanmukhS_Intel
Hi AlperenB,
Unfortunately, We could not provide the compatible .so files for VxWorks, as the new version of IPP does not support VxWorks.
Shanmukh.SS
ShanmukhS_Intel
Hi Alperen,
A gentle reminder:
As we haven't heard back from you, Could you please let us know if we could close this thread at our end if you do not have any further queries?
Shanmukh.SS
ShanmukhS_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
