Processors
14600 Discussions
Intel SU2700, T6400, T6500
There are laptops in the $500 to $600 range, all with 14.1" displays and similar memory/HDD setups. One of the differences is the Intel CPU. I've seen the SU2700 (new single core?), T6400 and now the T6500 (T6400 replacement?). I haven't purchased a new laptop lately in this category for awhile, so I'm interested in expert opinions on the relative performance difference I might notice using XP Pro (Vista if I need to) and Windows7. I'm more likely to multitask office and web-browsers than do any serious gaming. Other consideration is battery life - single core has lower max power, but how much of a difference should I expect?
John_S_Intel
The one suggestion I have is that if you plan to upgrade to Windows* 7 at any point in the future and wish to use Windows XP* applications (XP compatibility mode), make sure the processor supports virtualization. You should be able to verify whether or not the Intel processor in question supports Intel® Virtualization Technology (VT) by looking them up in ark.intel.com. http://ark.intel.com/VTList.aspx http://ark.intel.com/VTList.aspx
You can also compare the processors in question within ark.intel.com to see which has the features you need.
You should also check the Microsoft* web site to make sure your system is Windows 7 capable.
John S.
Intel Customer Support
*Other names and brands may be claimed as the property of others.
