Processors
14647 Discussions
Intel i-7 3610qm высокая температура под нагрузкой
АРеше
Здравствуйте.
При нагрузке, например компьютерные игры, температура процессора за полчаса возрастает с 50° до 90°, после этого начинает снижаться производительность процессора. Как понять нужно заменить термопасту или систему охлаждения?
IntelProcessor Diagnostic Tool показывает, что с самим процессором всё хорошо.
Hello Rikis,
In this case, you best contact support is your Laptop manufacturer as they are more familiar with your system and how all the components interact with each other.
The T-junction temperature for this processor is 105C so that temperature is fine; I know that it is high since the unit is idling, you can check the following link for some troubleshooting:
http://www.intel.com/content/www/us/en/support/processors/000005597.html?wapkw=overheating http://www.intel.com/content/www/us/en/support/processors/000005597.html?wapkw=overheating
Also, you can check some tips about fixing overheating issues with laptops here:
http://www.makeuseof.com/tag/fix-overheating-laptop/ http://www.makeuseof.com/tag/fix-overheating-laptop/
https://www.howtogeek.com/67660/how-to-diagnose-and-fix-an-overheating-laptop/ https://www.howtogeek.com/67660/how-to-diagnose-and-fix-an-overheating-laptop/
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
If the issue persists I strongly recommend contacting your laptop manufacturer for further assistance.
Ivan.
