Lga 775 problem
Computersman137
Hello Intel, I've got a problem with my motherboard. The LGA 775 socket has 2 pins broken. Can it still work ?
AlHill
I would not use it.  Where did the pins go?  In, around the socket? Somewhere else on the board?
No, too risky to use.
[If you find any Intel driver you might need, download and save it now.]
Computersman137
They go in the socket. It's the only Intel CPU motherboard that I have. The others are AMD'.
