- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
OS: Debian Linux, Netrunner 17.10
CPU: i7-4702MQ
Message from syslogd@deckweiss-pc at Dec 31 09:38:42 ...
kernel:[87870.907875] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 5: ae0000000040110a
kernel:[87870.907876] mce: [Hardware Error]: TSC 0 ADDR ffb01ec0 MISC 38a0000086
kernel:[87870.907880] mce: [Hardware Error]: PROCESSOR 0:306c3 TIME 1514709519 SOCKET 0 APIC 0 microcode 16
I am getting this error every time I wake my laptop up from suspension.
Everything seems to keep working though.
Any ideas?
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Deckweiss,
Thank you for contacting Intel Support,
I understand that you are having problems with your system since it shows an error every time the laptop wakes up from being suspended, I apologize for any inconvenience this may be causing.
Now, regarding the exact issue, we are uncertain as to what could be causing it or what it is, as I researched, it seems to be a problem with hardware, however I am not completely sure, I would recommend you to inquire about the error message on the Linux forums.
Also, some things I could recommend would be:
1) Re-install the operating system and check again if the error persists.
2) Try putting the BIOS settings back to default.
I hope you find this helpful.
David V
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Deckweiss,
I am following-up with your case and I see that we have not heard back from you,
Is there anything else I can help you with?
Were you able to solve your issue?
Do not hesitate to reply to this e-mail for further help!
David V
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hey, on the netrunner forums, I was told that it is most likely a broken acpi integration of my mainboard.
Updating uefi/bios, and doing a clean install of the os did not fix the issue though and I don't think my manufacturer (acer) will do anything about it, but I have not contacted them yet.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Deckweiss,
Thank you for your response,
I understand what you say, however if the issue is related to the motherboard only Acer would be able to assist you and see if there is a way to replace the motherboard (if applicable).
Those were the only suggestions I had regarding steps on how to fix the problem, I apologize for any inconveniences.
David V
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Deckweiss,
Do not hesitate to reply to this for further help!
David V
