Processors
14550 Discussions
Mce supports for Intel Xeon processor family E5-2658v4
ZZhu10
I'm adding hw resiliency check for our new board and need to know which kind of mcelog msg will be reported for this processor. Below are several fields I'm interested:
CPU voltage monitor?
QPI access between CPUs?
DDR4 DIMM access errors?
DMI operations to PCH error?
ECC error counts?
TLB hardware check error?
Will above error generate mcelog in linux kernel and populate to /dev/meclog?
Besides these, are there any other mcelog errors this processor support?
Ziang
Hello zzhu_juniper,
I understand you would like to know what type of mcelog messages the processor is going to report.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to know the model number of the server motherboard you are using and also the operating system you have installed in that sever.
Fred D.
ZZhu10
The system we are using is Wind River Linux. Version: 7.0.0.9.
CPUs we are using are Intel Xeon E5-2658V4 2.3GHz 14 core.
chipset is Wellsburg PCH (C610 series)
Any more data needed?
Ziang
Hello zzhu_juniper,
Thanks for the additional information you sent to me.
I recommend getting in contact with our developers so they can assist you better with MCE information. This link will give you their contact information https://software.intel.com/en-us/support https://software.intel.com/en-us/support
Fred D.
ZZhu10
I opened a ticket with the link you showed me. However, it was closed saying this issue is duplicate and resolved here. There is no reopen option there. Could you help me check?
Service request ID is: 03124755.
Ziang
Hello zzhu_juniper,
For some reason the system redirected the ticket to our support group. Another option would be posting your inquiry on our developer's forum through this link https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
Fred D.
ZZhu10
This question is keeping floating around. Could you help handle this to correct group?
Hello zzhu_juniper,
Let me do further research about this and come back to you. I will post information on this thread as soon as I have it available.
Fred D.
Hello zzhu_juniper,
For this inquiry the best option would be contacting our Resource and Design Center so they can assist you better. This link will give you their contact information https://www-ssl.intel.com/content/www/us/en/design/resource-design-center.html https://www-ssl.intel.com/content/www/us/en/design/resource-design-center.html
Bear in mind that you may need to register in order to get support from our engineers.
Fred D.
