Processors
14655 Discussions
Meu processador da erro de base block no progama de checagem
JJorg4
Intel Processor Diagnostic Tool
--- IPDT64 - rev 1.24.0.0 ---
--- Start Time: 09/27/2016 21:14:55---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 53 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i5-4440 3.10GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.10
Detected CPU Frequency is --> 3.10622
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
!!! --- Base Clock test Fail --- !!!
--- Test End Time: 09/27/2016 21:15:07---
Este e o erro que da na checagem do processador , gostaria de uma solução
I would recommend trying a bios update from your motherboard or computer manufacturer and run the Intel® processor diagnostic tool again. If the problem remains. Please contact Intel customer support and request warranty for your processor.
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Allan.
JJorg4
Gostaria de saber como atualizar as minhas BIOS . Se é um progama ou outra coisa ...
The BIOS update is an actual program you need to execute. You need to download it from your computer manufacturer's website or the motherboard maker.
Please check with the board maker for the latest BIOS update available for your computer model.
Allan.
JJorg4
A minha placa e da MSI eu ja baixei a Bios mais atualizada 6.70 , mas ainda continua dando erro de baseblock
At this stage, I recommend contacting Intel support for warranty on your processor, please see contact information below:
Allan.
Did you check warranty options for your processor at Intel?
Allan.
