Processors
14574 Discussions
My Intel Processor is 60% percent worn out, I have only had it for a year, does my limited warranty cover this (out of the box Processor) and if so how do I get a new one.
STwee
I did a check on my processor recently with a bench marking program because for a while ( I mean over the time of 3 months) my computer started to slow, I used a bench marking program and looked at the temps of my cores and it said my Processor was 60% worn out and over heating, when Idle it was going up to 70 Celsius and when I play a video game it was reaching 100! I didn't change the stock cpu fan, never overclocked it and never used new thermal paste until now, I went and got some new Thermal paste and that has kinda solved the problem but, (thermal paste should last longer than a year or about 10 months) I was wondering if wear n tear is covered, if so how do I go about getting a new one?
P.S I guess this is why I have a warranty.
Kevin_M_Intel
Hello Sammie,
There are some troubleshooting steps you can try if the processor is overheating. Check the following link:
http://www.intel.com/support/processors/sb/CS-029427.htm http://www.intel.com/support/processors/sb/CS-029427.htm
Warranty covers processor malfunctioning so I would like to know the following:
  1. What software are you using to benchmark the processor?
  2. Have you tried running the Intel® Processor Diagnostic Tool? If not, download it and run it:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit-
  1. Thermal paste will last depending on how many times you take the Cooling Solution out so it would be good idea to renew it when it looks dry.
Let me know the result of the Intel® Processor Diagnostic Tool.
Kevin m
STwee
Thanks for getting back to me Kevin!
I'm sorry I'm not that tech savvy.
I have never removed the cooling solution from my processer (I'm guessing you mean my CPU fan?) and I always give my pc a good clean every two months there is hardly any buildup of dust.
Here is the results of the test
and here is the Bench-marking website and software I used and it has my computer stats, says my core is 37% - the 4% (chrome is open)
http://www.userbenchmark.com/UserRun/194810 http://www.userbenchmark.com/UserRun/194810
can you tell me whats wrong with my Processor?
--- Testing Processor 1 ---
--- IPDT64 - rev 2.20.0.0.W.MP ---
--- Start Time: 03/26/2015 21:26:19---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 58 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-4770K 3.50GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.50
Detected CPU Frequency is --> 3.76801
CPU Frequency Test Passed!!!
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 101
Base Clock test Pass ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 432
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.31663e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Z87 SKU
Chipset Stepping : C1
2 device connected to PCI Express Port 0
1 : AMD Radeon R9 200 Series
2 : High Definition Audio Controller
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 3
1 : Standard AHCI 1.0 Serial ATA Controller
3 device connected to SATA Controller 1
1 : PLDS DVD+-RW DH-16AAS ATA Device
2 : ST3750528AS ATA Device
3 : WDC WD30EZRX-00DC0B0 ATA Device
3USB devices detected
1 : ASUS USB-N53 802.11a/b/g/n Network Adapter
2 : USB Composite Device
3 : USB Composite Device
1 device connected to Intel High Definition Audio Controller
1 : High Definition Audio Device
PCH LAN Device 'Ethernet Controller' detected
--- Platform Controller Hub Test Completed!!! ---
..Query 2..
--- Que...
Kevin_M_Intel
Hello Sammie,
Based on the Intel® Processor Diagnostic Tool results the processor is working just fine and the frequency and temperatures are good so this makes me think the bad results from the other software are because are simple not correct.
Kevin m
STwee
Hmmm so do you think it could be my hard drive that my Windows is on (its 3-4 years old) I read up about slow down with youtube and video games and crossed off the list of things that wouldn't cause this, I'm guessing its my old seagate hard drive.
What else could be causing my slow down ( I have ran many different malware programs and virus checkers, I didn't find anything)
Thanks again!
Kevin_M_Intel
We are not aware that software can tell that a CPU is 'x % worn out'. Can you please tell is what benchmark tool gave you that report?
Maybe the HDD needs a low level format? Is there a way to test another Drive perhaps?
