Processors
14755 Discussions
Need help on 3ghz processor compatibility
hi
i currently have spare 3GHZ Intel CPU with 1mb cache and 800 FSB. My current motherboard bios level is P08, if i updated to p13 level will it work in my Intel Desktop Board D865GLC ( last 3 numbers of board revision is 404)
its the cpu listed here http://www.intel.com/support/motherboards/desktop/D865GLC/sb/CS-026965.htm http://www.intel.com/support/motherboards/desktop/D865GLC/sb/CS-026965.htm
Without knowing your exact CPU.... but taking a guess from the specs you hvae given if you board is C31110-404 then with the BIOS update it will work.
