Processors
14696 Discussions
Normal E5200 Temperature Range
Could someone please tell me the normal CPU range for the E5200 when idle? (No OC, stock cooler) BIOS is giving me a reading of 42C and this seems a little high. Thanks!
Actually the temperature is fine as the max threshold temperature for the CPU is up to 74.1C
http://ark.intel.com/Product.aspx?id=37212&code=Intel%C2%AE+Pentium%C2%AE+Processor+E5200+%282M+Cache%2c+2.50+GHz%2c+800+MHz+FSB%29
All the best,
Aryan
I am getting 38 to 40 c in idle and 55 under full load that sounds normal mine is same e5200 no oc stock cooler
Message was edited by: farazejaz
Mine is usually between 45 and 50C - so you should be fine.
Jakob
http://www.kasinobonus.dk
