Processors
14643 Discussions
Olá, eu comprei um desktop com processador intel core I3-6100 com a bios version F2, system model name H110M-H DDR3, bios id 8A19AG0S pois na especificação deste processador informa que possui a função VT-x para possibilitar a virtualização. Ao instalar o
CCast11
Hi, i've bougth a desktop with a I3 intel 6100 processor, bios version F2, system model name H110MH DDR3, bios-id 8a19ag0s, and in the specifcation there is a information that this processor has the VT-x technology, but it has to be enabled and I didn't see in the bios setup, nothing about this enabling this feature. In the chipset section I see only information about VT-d feature enabling, nothing about VT-x although the specification says that this processor has this capability.
IUman
Hello Musicaboa,
Thank you for joining the Intel communities.
The Intel® Core™ i3-6100 Processor supports Intel® VT-x with Extended Page Tables (EPT) as you can see at:
http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz http://ark.intel.com/products/90729/Intel-Core-i3-6100-Processor-3M-Cache-3_70-GHz
Usually this is enabled by default but if it is not you will need to contact your motherboard manufacturer to get help where you can enable that in the BIOS or if the option is available in the BIOS or not.
Best wishes,
Ivan
IUman
Hello Musicaboa,
Best wishes,
Ivan
