i have a pentium 4 650 HT 3,2 GHz/FSB 800 MHz, and i want to know if is compatible with motherboard P5G41T-M. Here
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&m=P5G41T-M&p=1 http://support.asus.com/cpusupport/list.aspx?SLanguage=en&m=P5G41T-M&p=1
i can see that it isn't support, but here on asus world:
http://www.asusworld.it/model.asp?m=Motherboard&p=19 http://www.asusworld.it/model.asp?m=Motherboard&p=19
in the list of cpu support, there is Pentium 4. Here for example sell P5G41T-M motherboard and in the list of cpu support there is pentium 4:
http://www.eprice.it/Schede-Madri-ASUS/d-2416217 http://www.eprice.it/Schede-Madri-ASUS/d-2416217
what is the truth? is support or not? I have read that new chipset, like G41, support also older CPU that normally don't support.- Mark as New
The compatibility between Intel processors and any third party motherboard is determined by the motherboard manufacturer, in this case by ASUS*.
So what you need to do is to call ASUS* support so they can provide you the right answer.
You can find contact information for ASUS* support at:
http://support.asus.com/contactus.aspx?SLanguage=en http://support.asus.com/contactus.aspx?SLanguage=en
