17260 Discussions
Pentium 4415U / Windows 11
Kind1
Hello! I downloaded the program to check that my laptop was compatible with Windows 11. I was happy to find out that all of the items were supported, but I was immediately frustrated to find out that all of the items were supported except for one: the processor. Why is the Intel Pentium 4415U Gold not supported in Windows 11? After all, it's a great processor! I even manage to play games. Plus, Windows 10 support will end soon. Why not extend the life of a lot of devices? The processor passes the system requirements (At least two cores clocked at least 1 gigahertz (GHz) on a compatible 64-bit processor or System on Chip (SoC)) Thanks for the reply!
AlHill
Your processor is not supported by Windows 11, because Microsoft says so:
https://learn.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
Take your complaint to them.
Minionguyjpro
You can install Windows 11 unofficially on your device:
The easy way to install Windows 11 on unsupported CPUs - The Verge
I installed Windows 11 on my Lenovo Ideapad 320, with an Intel Pentium Gold 4415U, like yours. I also had everything being met, except for the CPU. Installed Windows 11, and it works as good as Windows 10 does! Microsoft says support for updates isn't there, but everyone including me still receives all updates.
AlHill
And, when Microsoft stops the updates, or you have other problems, will you be crowing as loudly?
Minionguyjpro
Microsoft says that updates are not guaranteed, I don't know a date. I am still getting security and other updates. I did not find any problem yet, it runs as good as my Dell laptop officially running Windows 11.
Minionguyjpro
I am currently installing Windows 11 23H2 on my Dell laptop. Later I will install the 23H2 update on my Lenovo IdeaPad 320 laptop with the Intel Pentium Gold 4415U too.
TechnologyGuy
Intel Pentium Gold 4415Y CPU is really what I use on my Surface Go 1. The reason why it will not support Windows 11 because it was released earlier than 2018, making the mobile entry-level processor not strong enough to run Windows 11, but is built to run games like Minecraft bedrock edition
AlHill
@TechnologyGuy   This thread is two years old.
[CoPilot is a virus]
