Hi, i have a Toshiba Satellite M115-S3144 laptop with a T5200 CPU 1.6 GHz 533 FSB with Socket 479 mPGA. I wonder if there is posible tu upgrade the cpu with out afecting the machine, with the same fan. I want to install a T5870 CPU 2.0 GHz 800 FSB. Thanks in advance.
You will need to find out if the CPU is compatible with the motherboard.
