Processor Speed
EB74
Hi I am using a laptop with an intel core i7 -1265U processor to run engineering simulation software - the base speed for this processor is given as 1.8GHz but it has a 'Max Turbo Frequency' of 4.8 GHz. I am considering investing in a desktop with a faster processor in order to speed up simulations - but I see that base frequencies are not given for the newer intel processors - and therefore am finding it difficult to make a direct comparison.
Would upgrading to a machine with for example an i9-13980HX processor (Max Turbo frequency of 5.6 GHz) make a significant difference to single core speed?
(single core performance is what counts for the simulation software I am using).
Jose_Intel
Hello @EB74
Thank you for posting on the Intel️® communities.
We specified the Base Frequency for our products prior to 12th Generation Intel® Core™, it is no longer a suitable metric to use for comparing the performance of processors from different lines and/or generations. We recommend using multiple factors like the processor base power and turbo frequency in order to evaluate the performance of the processors.
Here you can check the comparison between the Intel® Core™ i7-1265U and Intel® Core™ i9-13980HX
I hope the information helps, thank you for understanding.
Jose B.
EB74
Thank you Jose for your reply.
Am I right in thinking that a higher processor base power corresponds to a capability to run at higher CPU speeds for longer periods (without thermal throttling occurring)?
with thanks,
EB74
Jose_Intel
Hello EB74
Thank you for your reply.
Since the Base Frequency is no longer a point of reference to compare the performance, our advice is to compare other values to always have the best product according to your requirements.
Jose B.
