17308 Discussions
Processor motherboard RAM compatibility?
LMile6
Hi, I am currently using an Intel I3-2120 and I am looking at upgrading to an I5-9400F processor, do you know if the motherboard and RAM will be compatible or if I will need to upgrade it, thanks
AlHill
You must contact the motherboard manufacturer and ask them what processors are supported by your board's bios. Then, you can select from those processors.
It is extremely unlikely that you can do the upgrade you want. You are talking about SEVEN YEARS difference.
Doc
n_scott_pearson
Upgrading to the i5-9400F processor will require that you also replace both your motherboard and memory.
