Processors
14711 Discussions
Ram problem, CPU it's the cause?
AMerc7
i have this problem: http://yfrog.com/e6ramproblemmbinfoj
i have this pc: CPU: Intel Core I5 750 @ 2.66 GHz, MOBO: Gigabyte GA-P55M-UD2, RAM: 2x2GB Corsair XMS3, VGA: Sapphire 5770, ALI: Corsair 550W
i just have contact Gigabyte, and after some attempts, they said to me this:
Dear Alessandro ,
The problem might caused by pins on CPU socket. Bent pins might cause system memory size incorrect. Please check the pins by fowllowing steps:
http://www.intel.com/support/processors/sb/CS-030850.htm
A further testing or examination to your system might be required. We suggest you to contact your supplier or nearest distributor and see if they help you to test your system directly.We are really sorry for the inconvenience you have with our product.
GIGABYTE TECHNOLOGY
Can you confirm about pins? i won't pay any technician for anything...
MWong22
New Contributor II
take out your processor and check the pins whether is it bended?
AMerc7
I've never taken out a processor, I've fear to damege the cpu... so i ask before here if it can be the cause...
MWong22
New Contributor II
you need to take out the CPU in order to check whats really happen to the problem..
just make sure, nobody is disturbing you..
in a quiet room...
and slowly take out the fan.. and slowly take out the CPU.. and
the moment you take out the CPU. it will be very obvious to see whether is there any bended pins on the Processor socket..
if there is.. please get the black plastic processor cover to protect the processor contacts..
and send the board for repair
AMerc7
ok i will do it, but now i'm so busy...
