Greetings I hope you can help me.
I use Win Vista Home Premium x64 and have the Intel(r) Core(TM)2 Duo CPU E8500.
All works fine so I dont have any problem. But i wonder cause the windows hardware manager which shows all hardware shows an issue with the SM-Bus-Controller.(yellow Attentionmark).
Due Internetsearch i found out it has to do with the processor. That why i ask here.
As I dont have problems i dont care. but I'm curious if its an issue.
Thanks for the help.
As I'm german I don't mind if one answers in german but english is fine too.
Extract the latest chipset driver manually.
Here is a guide how to do it:
http://communities.intel.com/message/91830# 91830
Then try to install the unknown device manually from device manager by browsing into the extracted folders.
All the best,
Kind Regards,
Aryan.
Thanks for the answer.
But it seems that on the intel homepage there is no correct driver aviable. Or do I have the wrong link?
Try this link:
All the best,
Kind Regards,
Aryan.
