Processors
14735 Discussions
SUBSTITUTION PENTIUM 4 with CELERON 430
Substitution CPU processors:
I have two pc fujitsu: SCALEO J ms-7275 WITH PROCESSOR PENTIUM 4 524 3,06 GHZ 533MHZ
And
SCALEO P MS-7275 WITH PROCESSOR PENTIUM 4 630 3,06 GHZ 800 MHZ.
And an OLIDATA Ser N. 1087 8019 MB ASUS P5RD2-VM RXP200 S755+V+L+S6 Mkt name Alicon 4 EFNA mod Denver prod 04/2006 with cpu PENTIUM 4 531 3,0 GHZ 1M 800 MHZ X64
(I do not succeed to understand what chipsets they have, if someone kindly tell me it it's better. ... ..)
Since these all pentium with core Prescott and socket 775 are too hot and progressively 'cook' themselves and die, 524 is almost ko, I would like to replace them with these 3 processors LGA 775 still available on the market:
CELERON 430 1,8 GHZ 800 MHZ, L2 512 KB 64 BIT, 35W
CELERON E3300 2,5 GHZ 800 MHZ, L2 1 MB, 65W
PENTIUM DUAL core E5400 2,7 GHZ, 800 MHZ, 65W
CAN I DO IT? ARE they COMPATIBLE? wich of 3 cpu equivalent you would choose? ,
What setting, bios particularly, I should change?
I would like the celeron 430, weaker but colder, and of minor cost, seen that in the difficult dismantling and assembly in the socket 775 i do not know how many pin and cpu i'll break. ...
can I replace the said pentium 524, 531, 630 with the Celeron 430 today in commerce? THANKS
Adolfo_S_Intel2
In order to determine which processors are compatible with your systems you will need to contact the motherboard manufacturer or the system brand manufacturer for them to provide you a list of supported processors for your particular motherboards.
