I changed something via the Extreme Tuning Utility, and my computer crashed. I am up and running, but want to make sure the values are all back to original, default values.
Is there a way to know if everything is back? I only changed 2 or 3 things but forget which.
Does Core Voltage Offset set to 0.100V seem ok? Core Voltage 3.99V?
thanks.
Hello jimlau
Thank you for posting on the Intel️® communities. You'll need to reinstall the Intel® XTU (uninstall it completely and then install it again) and run BIOS defaults to undo any changes on the values for overclocking.
For more information on running BIOS defaults, please contact the motherboard manufacturer.
David G
