Processors
14632 Discussions
Teste de processador Failed
segue erro abaixo:
--- IPDT x86 - Revision: 3.0.0.25.W
--- IPDT x86 - Start Time: 13/08/2016 16:42:01
Intel(R) spbc Module Test
Module Version: 1.0.7.32b.W
Start Time: Sat Aug 13 16:42:01 2016
Test Result - FAIL
..!!..ALERT..Processor under test is verified as 'SAMPLE'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Celeron(R) CPU 450 @ 2.20GHz
End Time: Sat Aug 13 16:42:02 2016
Total Time: seconds: 1
Genuine Intel CPU Test
Module Version: 1.0.12.32b.W
Start Time: Sat Aug 13 16:42:02 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 22 degrees below max
CPU Brand String Test
Start Time: Sat Aug 13 16:42:03 2016
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Celeron(R) CPU 450 @ 2.20GHz
End Time: Sat Aug 13 16:42:03 2016
CPU Frequency Test
Module Version: 1.0.14.32b.W
Test Result - FAIL
Processor Name: Intel(R) Celeron(R) CPU 450 @ 2.20GHz
Expected CPU Frequency: 2.20
Detected CPU Frequency: 0.700004
End Time: Sat Aug 13 16:42:05 2016
Total Time: seconds: 2
--- IPDT x86 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Information: x64 Family 6 Model 22 Stepping 1
Number of Physical Cores: 1
Number of Logical Cores: 1
Installed System Memory: 2 GB
Operating System: Microsoft Windows 7 Home Premium 32-bit
Graphics Information: Intel(R) G33/G31 Express Chipset Family
System Product: STI 005492
System BIOS: 0100
--- IPDT x86 - End Time: 13/08/2016 16:42:05
--- IPDT x86 - Result: Fail
Hello foliveirad1:
I just wanted to let you know that the support on our communities is provided using English or Spanish languages, so, we would really appreciate if you can use anyone of those so we can better assist you.
Thank you very much for posting those details on this thread, and based on that, we just need to verify some details:
What is the problem with the processor, what is the PC doing when you use it?
Did it work fine before?
How long ago did you purchase it?
What is the model of the motherboard?
Alberto
Hello foliveirad1:
I just wanted to check if you saw the questions we submitted above?
That information is very important for us to further assist you.
Alberto
