17080 Discussions
Unable to install Drivers
Soumyaray619
Just bought a new PC and Installed a fresh new windows 10, can't find the brightness slider bar, so I check the Device Manager and this is what I saw
My CPU is Intel Core i5 12400F with ASUS H610M-E D4 mother-board, The IDs are:
PCI Device 1
PCI\VEN_8086&DEV_7AA4&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA4&CC_0C8000
PCI Device 2
PCI\VEN_8086&DEV_7ACC&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7ACC&CC_0C8000
RAID Controller
PCI\VEN_8086&DEV_467F&SUBSYS_86941043&REV_00
PCI\VEN_8086&DEV_467F&CC_010400
SM BUS Controller
PCI\VEN_8086&DEV_7AA3&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA3&CC_0C0500
UNKNOWN Device
ACPI\VEN_INTC&DEV_1056
ACPI\INTC1056
*INTC1056
Stefan3D
You should get rid of the yellow bangs if you install the "Intel chipset driver" from
https://www.asus.com/us/motherboards-components/motherboards/prime/prime-h610m-e-d4/helpdesk_download/?model2Name=PRIME-H610M-E-D4
Soumyaray619
Couldnt find the driver for RAID controllerCouldnt find the driver for RAID controller
Couldnt find the driver for raid controller. thanks for that link
Stefan3D
There seems to be a bug in Windows update catalog, hence no automatic installation
https://www.catalog.update.microsoft.com/Search.aspx?q=PCI%5CVEN_8086%26DEV_467F
Try the newest SATA driver from ASUS support.
Soumyaray619
Tada!Tada!
Thank you! finally got rid off those yellow bangs.
